Connecting EETV box to Third Party Router
RachelAC68
Afternoon - because of ongoing frustrations with DNS/IP drop outs since August, I've invested in new router which works perfectly - and I have amazing net/service - HOWEVER - I can't sadly connect the router to the EE TV box.
Can anyone help - as it stands atm it cant find the name of the router even as a choice to join - which is frustrating.
Router is Asus GT-AX11000 Pro
I'm not very techy so any advise (in noddy and big ears terminology) would be welcome !!  Thank you
widdowsonben
Skilled Contributor
Skilled Contributor
Hi Rachel
Navigate to the routers homepage (http://192.168.1.1 or http://192.168.0.1) and click on WAN. Then scroll right to the bottom and untick Enable VPN+DHCP Connection and click apply. Then navigate to the LAN settings (above the WAN option you just clicked on). At the top you'll see an option for IPTV. Set it to the following:
Select ISP Profile: None
Choose IPTV STB Port: None
Use DHCP Routes: Microsoft & RFC3442
Enable Multicasting Routing: Enabled
Default IGMP Version: IGMP V3
Enable Fast Leave: Disabled
UDP Proxy: 0
That should work after a reboot. I find it performs much better over wifi though rather than via an ethernet cable for some reason.
Hope that helps.
EE / BTTV user since BT Vision - EE FTTC (Apple TV & Mini's) - Starlink Backup
9 REPLIES 9
widdowsonben
Skilled Contributor
Skilled Contributor
Hi Rachel
UDP Proxy: 0
Hope that helps.
Perfect - thank you SO much ♥♥  Works like a dream !
Absolutely no worries. I'm glad it works for you 🙂
I'm not going to promise you that it doesn't occasionally drop out but it works 99% of the time. Enjoy your new setup.
Evening,
I’m having the same problem, I have just switched to a NetGear ORBI33 Router WiFi 7 and the broadband speed and network coverage is excellent but I am unable to watch the EE Live TV channels on the EE Box. All the Apps work on the EE Pro Box i.e. streaming Netflix, NOW, BBC, Discovery etc, and I can see the TV channels along with the TV List but I just keeps giving me a failure message when I click on the channel.
I have done a reset on the box, rebooted the WiFi routers etc but I still keep getting the same issue.
Many Thanks
Mark
widdowsonben
Skilled Contributor
Skilled Contributor
Hi Mark
have you turned in IGMP snooping on the router? It’s disabled by default.
Good Morning - Yes I have changed it to IGMP Version: Auto and ticked Support British Telecoms (BT) IGMP Proxying as per the screen shot below. Thanks
widdowsonben
Skilled Contributor
Skilled Contributor
have you tried all the ethernet ports? Ive seen a few routers insist on using a specific port sometimes.
DarrenDev
EE Product Expert
@Mark-13 it's interesting that they specifically have a setting for BT IGMP. By adding that, they've declared support - and therefore it'd be perfectly reasonable for you to call their support desk to ask for help with it.
widdowsonben
Skilled Contributor
Skilled Contributor
Also have you tried connecting the box by wifi? As stupid as it sounds ive got both a TPLINK and an Asus router ive used with BTTV previously. The TPLINK works fine but i can only get the Asus to work with BTTV via wireless.
