25-06-2025 03:48 PM
I switched from BT to EE two days ago. I have a new Panasonic fly tv which I have set up. The first issue I have is with the clock display which doesn't sync with BMT, it is currently over 9 hours behind.
The second issue is I am unable to get the live HD channels for BBC 2, channel 4 and channel 5. I have followed the on screen instructions and retuned the channels but still no connection. I have connected to the tv aerial which I assumed I would need to watch terestial tv. Please help
27-06-2025 08:19 AM
25-06-2025 06:37 PM
Hi @Yorkshire-lad80
Have you taken EE TV service with your Broadband? If so which EETV box do you have?
Ali
26-06-2025 04:41 PM
26-06-2025 04:57 PM
So the issue is with your Panasonic TV, rather than anything BT or EE related?
Has this TV worked correctly before? Or is this you setting it up for the first time?
26-06-2025 08:22 PM
27-06-2025 08:04 AM
OK, this would be better suited on a Panasonic forum then, but no problem.
I would have expected the TV to automatically set the time based on the TV aerial signal, or at the very worst, synchronised with online when it was connected to the internet. It's possible that it thinks it's in a different time zone? You could try Googling for your specific model of TV to see if there's a guide on how to set the time and time zone?
Regarding the missing channels - that'll be entirely down to the signal that your TV aerial is receiving. There are 4 transmitters serving your area - 2 of them offer a very good signal, 1 is marginal, and the other is poor. It's possible that your aerial is pointed to a less than optimal transmitter? A local TV aerial installer may be able to help. It's odd that you'd have BBC 1 HD but not the others though.
27-06-2025 08:19 AM
30-06-2025 05:44 PM
Thanks again. The tv is now fine. Over the weekend the clock automatically changed without intervention and I now have all the HD channels. It must have been teething problems from the broadband switch and setting up a new tv. Thanks for your rapid responses. We are now happy viewers 😀
30-06-2025 06:04 PM
Very glad this is now sorted for you @Yorkshire-lad80
Thanks for popping back and letting us know.
Come back to the community anytime.
Leanne 🙂
