15-02-2025 09:39 PM
Moved to EE this week after 25 years with Sky. Generally all fine BUT….
despite 500MB download speed to the hub the tv box keeps crashing out of movies being streamed via the Apple TV app. I’ve done everything except a full reset. Any ideas what’s wrong with the TV box?
17-02-2025 05:37 PM
Hi @Burnziz
Thanks for coming back to us.
Could you try the steps in our EE TV Box Not Working or Keeps Freezing to see if the steps help get the connection issues sorted when using the apps.
If this continues, or you have tried everything, please get in touch with our technical support guides. The team will be happy to get this looked into for you 🙂
16-02-2025 09:36 AM
Hi @Burnziz
Welcome to the community.
Are you finding that this is on happening on the Apple TV app or have you noticed it on anything else?
Do you have the EE TV Box Pro or is it the Apple TV Box?
Is the box connected to the router by ethernet or WiFi? If it is WiFi, how far away from the router is it?
Michael
16-02-2025 01:59 PM
16-02-2025 02:01 PM
Thanks @Burnziz
Michael
17-02-2025 02:32 PM
It’s less than 10 feet through an open door and connected by WiFi.
17-02-2025 05:37 PM
Hi @Burnziz
