Can I have two Pro boxes?
philwolstenholm
I am an EE subsciber and I have a Pro box in one room and a mini box in another room. Is it possible to change the mini box for a Pro box so that I have two Pro boxes and no mini boxes?  Want to put a Pro box in the second room as it is a better piece of kit which has a recording facility. Would it work?
Michael_D
Hi @Caseyadams94
We're not able to supply you with two EE TV Box Pro boxes, you'd only be able to have one on your account.
Michael
6 REPLIES 6
Northerner
Hi @philwolstenholm
There are other threads on this but unless something has changed then EE will only supply one Pro box.
zulu17
Star Contributor
Star Contributor
EE TV extra box addon comes with a loan EE Box Mini . No other loan box options are currently offered and no indication of EE changing  that strategy.  So getting a second Box Pro from EE is unlikely. Were you to actually have a second recordable box then  it should  currently work if used instead of the supplied EE Box Mini. It is unclear how those individuals or retailers who sell Box Pros are sourcing their boxes. EE and BT have not relinquished ownership of box pros supplied  on loan as part of their EETV  contracts.
Profile closed
Not applicable
Yes it would.
You would need to acquire a Pro Box yourself from a third party such as eBay or CeX, then you swap it for the Mini and when you get the message “Too many boxes on your broadband”, you say “Yes” to making the Pro Box your ‘main box’.
The caveat is as outlined by others, technically EE boxes of any flavour are no one’s to sell, they are loaned and should be returned at the end of a subscription. So, whilst this works currently, BT/EE could choose to block it in some way in future.
Lastly, if you don’t have Full Fibre, recording multiple streams on two Pro Boxes will eat up bandwidth.
So it is possible to have two boxes that record? I really want one for my room so that I can record the football
Michael_D
Hi @Caseyadams94
Michael
Profile closed
Not applicable
Mine was the “Profile Closed” that you replied to.
Yes you can, just not from EE directly/officially, as has already been confirmed. Extra costs are involved.
  1. Firstly, you need to subscribe to “Extra Box” at £10 per month. EE will send you an EE TV Box Edge
  2. Secondly, you need to acquire an EE TV Box Pro from a third party, such as eBay or CeX or similar
  3. You do not take the EE TV Box Edge out of the box, once your Extra Box subscription is live, you start using the EE TV Box Pro you have acquired
Caveats haven’t changed as far as I am concerned:
Technically EE boxes of any flavour are no one’s to sell, they are loaned and should be returned at the end of a subscription. So, whilst this works currently, BT/EE could choose to block it in some way in future.
