Apps not opening with ethernet
Algi67
Hi, just had EE Pro Hub installed to replace BT home hub . On WiFi Now, ITV and our LG TV apps work. Our sound bar can’t be found ! If I plug in the Ethernet cable the sound bar restores but some of the Apps (Now, ITV and our main LG app doesn’t work … as some as I unplug the Ethernet cable the apps all work again !! Any thoughts what’s going on here ????
@Algi67
 How is your sound bar getting sound from your TV ?  Is that via
HDMI ?
Optical Cable?
Bluetooth?
Or WiFi ?
Where are you plugging in the Ethernet cable ?
HDMI and Ethernet cables
