Apple TV hide channels
Wattone
Hello can set favourites but how do I hide channels on re Apple TV guide please
th_2001
Not an option at the moment. Hopefully EE will have this change in mind
th_2001
Traynor78
I've found that once you select your favourite channels, you can then set a filter to display Favourites only; but you have to set this filter each time you pull up the TV guide - I don't think you can set it to be the default display.
