Another Netflix issue
nfg
Chose Netflix as a reward but still can’t access it. No text or email with a code (I have checked). How can I get access?
6 REPLIES 6
Rach_H
Hi @nfg,
Welcome to the Community!
We want to make getting your Netflix setup as simple as possible, so I'd love to help. Do you have an existing Netflix account that you're looking to link, or are you setting up Netflix for the first time?
Rach
Gail75
Experiencing the same issue also
Alex_H
Hi @Gail75,
Is Netflix an inclusive extra as part of your mobile plan? If so have you visited ee.co.uk/netflix to try and activate it from there?
If Netflix is included as part of your TV package, check your original order confirmation e-mail for activation instructions or login to your EE online account and you should be able to activate it via the Manage TV and Sport section.
Alex
No it's my Frist time
Ok
Leanne_T
Hi @jamiejeffers
Thanks for posting on the community.
Do you have Netflix included as an Inclusive Extra as part of a mobile plan? If so, have you had a text message with a link to get set up?
If you have an EE TV package with Netflix as an extra, can you check the confirmation email, do you have a link to get set up?
Leanne 🙂
