on 25-01-2026 01:50 PM
I'm using a 4g aerial to get my broadband on a business tariff with EE can I get EETV ??
Solved! Go to Solution.
on 25-01-2026 03:51 PM
Hi @MikeSkerrett
Welcome to our community.
EE TV is only available with fixed line broadband connections and not our mobile broadband option.
If you would like to look at switching in order to take out EE TV, our team will be happy to discuss options with you.
Lesley
Hi @MikeSkerrett
Lesley
on 25-01-2026 04:33 PM
Why is that - I currently have my BT TV box plugged in to my new router from my EE aerial and things are working fine - so what's the problem ??
on 25-01-2026 04:36 PM
You're only getting the aerial channels - they'd work without an EE TV box. None of the subscription channels work, as they're delivered using multicast over fixed broadband. The apps will work, but you don't need an EE TV box for those either.
on 31-01-2026 01:59 PM
So today I disconnected my BT Broadband router completely and plugged in to my EE Router receiving a signal from an aerial. I have been able to watch Now TV, Netflix, Amazon, Discovery Plus and it's recognising things I've tagged in My Tv on all of those channels. The only thing is doesn't pick up is EE TV how ironic when it's EE Broadband I'm using !!
on 31-01-2026 02:04 PM
Exactly as I said @MikeSkerrett - you're able to use all of the services that you could have bought without taking an EE subscription. Nothing you're consuming via that connection is coming from EE.
on 31-01-2026 02:33 PM
But I haven’t bought any of those services separately - they are all part of my BT TV package which is still in place until Feb 13th so I’m getting all of the things which I currently subscribe to via EE Broadband and TP router ?
