I am receiving no service available emergency calls need to get service working
HolyGrail2023
HolyGrail2023
actually i resolved by re-registering EE as my provider not sure how it deleted in the first place
7 REPLIES 7
@HolyGrail2023  Use THIS to see if there’s a network issue in your area.   Make sure you click the check status tab.
You could try using Wi-Fi calling if you are connected to a router via Wi-Fi
HolyGrail2023
thanks Chris i had done this before i raised a ticket to be more specific it states NO NETWORK REGISTERD for me i have removed an replace my sim and still get the same messgae
Hi @HolyGrail2023
Are you a PAYG or pay monthly contract customer?
Is your device from EE?
its is a corporate account yes and EE is the provider
James_B
EE Community Manager
Hi @HolyGrail2023,
Are you only having issues in one location or everywhere?
Can you make calls using WiFi Calling?
HolyGrail2023
James_B
Glad you got it sorted @HolyGrail2023 🙂
