Web Protect
diabhal
Having problems connecting to web protect to turn it off. Keeps saying there is a problem and they are trying to fix it.
I got it working, it was on my website hosting.
8 REPLIES 8
diabhal
I'm having the same problem, I can't view my website. The app is rubbish, when I login (I have seen faster snails) and go to manage web protect it says they are having a problem with it.
And going to the EE site to change settings doesn't work either.
We pay enough for their services, as loyal customers we should have, tech support on hand asap if needed.
They need to update the app it's 2 slow, and doesn't work. They should have stayed with BT at least their tech support was good.
Christopher_G
Hi @diabhal
Welcome to the community.
If you're having the same problem using a couple of different devices/browsers, I definitely recommend speaking to our technical support team so they can look into it further for you.
I was talking to tech support, they said only I can turn it off. I asked if I gave them my login information could they do it and they said no.
I will figure it out myself
@diabhal , do you mean the web protect from VPN? If that is the case, you should have the app and can do it from there, using the app and clicking on insecurity and switching it off there.
No not VPN
On the app when I go into manage and click on web protect it says:
This service isn’t working right now
We’re working hard to get it up and running. Try again later, visit our website or get in touch if it’s urgent.
Will try it again tomorrow
Leanne_T
Morning @diabhal
If you have the same error message today, could you try turning the router off, deleting and reinstalling the app and turning the router back on to connect again. Does this work for you?
Our Using Web Protect on EE page has details on Web Protect and how to manage the settings 🙂
Leanne_T
Thanks very much for coming back and letting us know @diabhal
Glad this is working for you 🙂
