10-02-2026 09:08 AM
How do I uninstall and reinstall cybersecurity from my iPad? I’m not sure I installed it correctly in the first place.
10-02-2026 11:10 AM
Hi @GGW1,
Thanks for visiting the EE Community
If you have set it up you should have the EE Cyber Security app installed on your iPad and if you want to uninstall it you just do the same as uninstalling any other app on your iPad.
To reinstall it you would just login to your EE account on your iPad and go to the add-ons section and select EE Cyber Security and Manage, then it will take you to the app store to reinstall the app. Once installed open the app and follow the steps to complete setup. Norton have a guide available for setup.
Alex
10-02-2026 11:10 AM
Hi @GGW1,
Alex
