Scam caller
Dionysius
Recently received a call that I think was a scam from 01975 228452 (Aberdeen). Not sure if they use a VPN or have a location in Scotland - hopefully not.
The usual noise in the background from other Indians making scam calls and the caller put the phone down when i repeated not wanting a different plan after his reassertion that he could  save me money.
Ali_A
Hi  @Dionysius
Welcome to the EE Community
You can check if a call is genuine and from us on our How Do We Contact You page.
Or if the call was from our Direct Partners at Phone numbers EE partners will call from.
If you're concerned about unsolicited contact from other companies, you can visit How to avoid and prevent scams including phishing, vishing and smishing for hints on how to block and prevent these.
You can also report the call to be investigated at Report a scam call | Help
Alternatively, text CALL followed by the number that called you, to 7726 .
Ali
Ali_A
Hi  @Dionysius
Ali
