20-12-2024 04:56 PM
Been getting calls from constant numbers when I google it says scam or likely business and does not go to EE sites here’s a number 020 3103 7341
21-12-2024 08:28 AM
Hi @Ortonn77
Welcome to the EE Community
You can check if a call is genuine and from us on our How Do We Contact You page.
Or if the call was from our Direct Partners at Phone numbers EE partners will call from.
If you're concerned about unsolicited contact from other companies, you can visit How to avoid and prevent scams including phishing, vishing and smishing for hints on how to block and prevent these.
You can also report the call to be investigated at Report a scam call | Help
Alternatively, just text the word CALL followed by the number that called you, and sent it to 7726
Hope this helps!
Ali
