24-04-2023 10:07 AM
Since trying to download an esim on my new contract phone, my phone has been out of use - no phone signal at all. Can't even log into my EE account! Have spent several hour on the phone and been told it was a single user fault but no phone seems to be able to ifx it. 5 days without my phone and the tech care team can't chas e it for me as they can't contact them apparently! What should I do? Am losing faith that it can sorted. Also spent 90 minutes in EE store - they couldn't fix it either. Was referred to a higher level of tech support 5 days ago - still ot heard from them.
24-04-2023 12:21 PM
Hi @sue_hawes
Welcome to the community.
It sounds like it's being investigated by our higher level technical support teams. Hopefully they can get to the bottom of the problem soon. Did they take an alternative contact number to get in touch with you on?
24-04-2023 01:18 PM
Yes they did. It's frustrating that the techincal customer support team (a very helpful person called Ruth) can't tell me how it's going or when it's likely to be mended if at all. I've been without a phone for 5 days now and have spent hours either on the phone or on store trying to resolve it.
24-04-2023 05:07 PM
Hopefully they're in touch with you soon, @sue_hawes. If you would like to chase this up, I'd recommend calling our Mobile Care team.
04-05-2023 07:21 PM
Hi Sue,
I’m having the exact same issue as you. Just wondering, did you get this sorted eventually?
