14-08-2023 01:00 AM
Hi.
please can someone help me I have tried everything I can think of.
I put my old sim into my new device and thought all was OK until I realised my phone is dual sim and I Had put the sim in the wrong slot than my phones settings were set for.
I removed the sim and changed to slot 1 but now it says sim locked and to unter a puk code.
I have accessed my account and to be honest I am finding it as USELESS AS A CHOCOLATE TEAPOT
It has taken me almost 4 hours of attempt to access my account and get to the manage device and sim option. Only to find the is no option to even obtain a code
So I thought I would request a second sim on my account to download and be able to use to contract EE then use it in my phone now I know its dual sim.
It was looking promising until it said almost there we just need to verify you and sent a pin code that I can't access because my sim is locked!!!!!
I have been without the use of mobile network for what will be 3 days tomorrow and it is causing me extreme issues as I didn't know I only had use of my home WiFi connection from the getup until I went to lend a normal sms message
Please can someone tell me how to fix this!!
06-12-2023 08:46 PM
amazing - why is this link not on the app or anywhere other than here????
07-12-2023 08:08 AM
Hi @Maya26
You can find the PUK code within your EE account online if you select Settings and Unlock device, this is not within the EE app.
07-12-2023 08:19 AM
You literally can’t. There is no “settings” choice. Have you tried logging into an EE account ???
07-12-2023 08:26 AM
Hi @Maya26
Sorry, this is located within Plans and Subscriptions, Manage Mobile, then under Phones and Devices, 'Unlock your SIM/eSIM' the PUK will show for you.
