28-05-2026 08:43 PM - edited 28-05-2026 09:16 PM
Hi, last week I broke the screen on my iPhone 14 Pro. I borrowed my friends iPhone 11 until I could afford to fix my screen but my sim wouldn’t work in it. EE sent out a new sim with the same number, that arrived & started worked in the iPhone 11.
I got my iPhone 14pro screen fixed this evening. I signed out of Apple ID, & removed the iPhone 11 from my Apple ID.
I put the newly working sim in my iPhone 14pro….but now I have no signal. The sim is okay though, as it works in a friends ancient phone.
Why is my iPhone 14pro not receiving signal?
29-05-2026 08:14 AM - edited 29-05-2026 08:15 AM
Welcome back to the Community, @emilyh85.
Just to be sure, was it after completing set up the iPhone 14 Pro that you tested the SIM in your friend's phone, or before?
When you set up a new iPhone it will ask if you want to convert your existing SIM to an eSIM, and some customers can accidentally end up cut off when this is the case.
Provided all of set up is complete, I'd recommend testing a SIM that's known to be working in the iPhone 14, too.
If this also doesn't work, and you have no luck with a full reset, it's likely a faulty handset and you would just need to give our team a call so we can look into repair options.
Peter
Peter
29-05-2026 12:01 PM
Was this repaired by an Apple Authorised Service Provider?
It's possible the antenna could have been damaged during the repair, is it reduced signal strength you're experiencing or nothing at all?
If the SIM works in another device, it usually indicates a device fault? Have you tried swapping the SIM back to the working phone to double check?
