Ported but Text issue
BillMcD
Recently ported over to EE from Vodafone keeping my original tel number  ,  when calls are made from mobile to any landline or other mobile my original number is displayed correctly on receivers handset. ...............But, if i send a text message from my phone the number displayed on receiving mobile is not my number, its displaying the number that came with the SIM .
...any ideas?   is this an issue with a set up in my Galaxy A72 phone or an issue with my EE setup ?
Chris_S
Hi @BillMcD Thanks for getting in touch with us here in the EE Community and telling us about this.
It may take a little time for your number to fully port into us after you've provided your PAC, You can find more information here
I'd recommend giving us a call so that a guide can get access to your account and give you an update.
To speak to a guide, just call a number that you can find in our Contact Us page
Chris S
9 REPLIES 9
Chris_S
Chris S
How recently is "recently" that you ported-in - can you be a bit more exact? Port-in should occur within a working day of providing your PAC, assuming that's done during working hours.
Is this only affecting "new" text messages you send, or existing conversations? If you've received the "port-in complete" text message, there shouldn't be any delay beyond that unless something is awry. Verify by texting NUMBER to 150 - is the correct response received?
Thanks for your response,  the "porting" was carried out more than 6 days ago, and i have had other issues where my new number was still coming up when calling other phones (not my ported number)  and this was on day 3 and 4 after porting was reported as being completed, after calling  150 this was sorted and i was informed that everything on the account was correctly set up.   Now i discover that texting is an issue as described above,   looks like another phone call to 150 to resolve this texting issue............not the best start to a new contract!!!
@BillMcD , what phone do you have? If IPhone you may have to disable FaceTime and IMessage, reboot and see if that makes a difference and once that is sorted, re-enable FaceTime and IMessage.
Samsung Galaxy A72
Katie_J
Hi @BillMcD.
I would recommend giving us a call so our customer care team can ensure your port has completed correctly.
Please be sure to keep us updated.
Katie
Hadrianlear
Same here
ee_user14
Prodigious Contributor
@Hadrianlear wrote:
Same here
Same advice then
Leanne_T
Hi @Hadrianlear
If you get in touch with our technical support guides, they can get the port looked into and help with your text issue.
