PAC code
Gingedraw
I called EE to request my PAC code and was given a 3 digit number. I was told not to use this number until the end date of my contract. I did what was asked buy my code does not work. I have attempted to request a new code by texting the number suggested but it does not recognise my details. I have searched online and it appears that the number I was given was incorrect as I should have been given 3 letters and 6 digits. I am keen to keep my number. Can anyone suggest how I do this?
Thanks in advance
1 ACCEPTED SOLUTION
Alex_M
Star Contributor
Star Contributor
Hi @Gingedraw
Just text PAC to 65075 from the number you want to keep. As you said, it should return your pac code to you.
If you are having problems getting it then I would suggest that you get in touch with the mobile care team by calling 150 from your EE mobile or 07953 966 150 from any phone.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Alex_M
Star Contributor
Star Contributor
Hi @Gingedraw
Thanks,
Alex
