Help needed
Andy713
The same thing happens to me as well.
[Mod edit: Title added]
Alex_H
Hi @Andy713,
Thanks for visiting the EE Community
Does restarting the phone also resolve your issue only for it to come back later? If its a physical SIM have you removed it from the phone to gently wipe it to make sure no issues there?
If the issue is continuing I would recommend getting in touch with our technical team and they can take a look and help with a replacement SIM if one is needed.
Alex
Alex_H
Hi @Andy713,
Alex
