on 04-01-2023 10:15 PM
Hi
basically by mistake i convert my sim on esim now i want to use physically sim what should i do now. And can i replace my sim at store.
thanks
Solved! Go to Solution.
on 05-01-2023 08:32 AM
Hi @Zahid8
Welcome to the community.
Yes, they should be able to replace the eSIM for a physical SIM in store for you.
Hi @Zahid8
