on 25-07-2022 10:48 PM
I activated an esim, but it's not working and my original physical sim card is not working as well, any solution or do I have to go to the EE store to solve it?
on 26-07-2022 08:26 AM
Hi @karoda
Thanks for coming here 🙂
Which device are you using?
Do you have no signal showing?
on 26-07-2022 09:46 AM
Hi @Leanne_T
I am using iPhone XR, and it shows no service. Thanks
on 26-07-2022 09:51 AM
Thanks @karoda
Have you followed the steps in our How do I use Dual SIM with an eSIM for iPhone, Help page to set up the eSIM?
on 26-07-2022 01:01 PM
The last three hours
on 26-07-2022 01:03 PM
on 26-07-2022 01:08 PM
on 26-07-2022 03:00 PM
@Leanne_T Yes, I activated the esim and got a new number for it, but both the eSIM and my original number all shows no service, now I can not make any call
on 26-07-2022 04:08 PM
Hi @karoda,
If you activated an eSIM with a brand new number, it shouldn't affect any existing SIMs on your account.
Please get in touch with Customer Care so a member of the team can take a look at this for you.
They'll be happy to help. 🙂
on 05-10-2022 06:24 AM
I am having the exact same problem, did you find a solution.
