ESim Transfer- Multi Phone
SparkTheFloof
I recently just got a 2nd Smartphone on for Work and 2 for Traveling and Events.
Is there a limit to how many time eSims can be swapped since Samsung and EE does not support sim transfer as of yet.
Ritu_D
Hi @SparkTheFloof
As Chris B mentions above a physical sim card would probably be the best option so you can just remove the sim and place in the device you want to use.
If you did want to get a replacement eSim here is info on how to Set up and use an eSIM
Ritu
@SparkTheFloof  you can swap the eSIM as many times as you like, but you’d be better off doing this with a SIM card if possible.
I was original thinking about doing a SIM swap but I been set up on eSim.
I was kinda hoping Sim Transfer would work but it's no supported.
Ritu_D
Hi @SparkTheFloof
Ritu
