on 14-03-2024 04:52 PM
Hope I'm in the relevant forum. If I run out of data on my EE PAYG sim in my 4G Wifi router, will it work with my Lyca phone sim, which uses the same network as EE?
Thankyou in anticipation.
on 14-03-2024 06:02 PM
Hi @alfie1953
Thanks for coming here.
If the router is unlocked you should be able to use any SIM card.
Could you try the SIM card in the router to see if this works?
on 14-03-2024 06:32 PM
Thanks for the response Leanne; the router is in my elderly Mum's house for the benefit of her carer, and I'm looking to pre-empt what might happen in advance of my next visit to see her! At which point I will hope to top it up, but may need a short term fix. It would be reassuring to know in advance that it will work!
on 14-03-2024 06:34 PM
I see and completely understand @alfie1953
You can check if the device is locked and request this to be unlocked if needed, using our Unlock EE Device to Use with Another Network, Help page. You would need the IMEI number for the router.
on 14-03-2024 06:51 PM
Aaah! I'll have a look. Although as far as I know my Lyca sim uses the EE network? So I won't need to unlock to use with another network? Thanks again, alfie
on 14-03-2024 06:53 PM
As this is a different network SIM card and not an EE SIM, we would advise to check the device is unlocked @alfie1953
on 14-03-2024 07:05 PM
As long as it's unlocked you may use any network's SIM in it. It will be if bought new after Dec. '21.
on 14-03-2024 07:07 PM
Ok, thanks, will do, although I'll obviously have to wait until I'm in situ to check the IMEI number. Am I wrong in thinking that my Lyca sim is using the EE network?
on 14-03-2024 07:20 PM
Aah, good news! It's a recent purchase, only bought 4 weeks ago, so should already be unlocked, if indeed it's necessary.
Thank you!
on 14-03-2024 07:42 PM
Yes, Ofcom forbade newly sold devices being locked from Dec. '21.
