on 20-02-2024 09:53 AM
My phone number has been ported yesterday and now I can't receive any phone calls.
Trying to sort this by calling 150 but no luck as this shows that automating everything and relying on "Computer says no" does not really work.
It is an iPhone8 and I have reset the network setting multiple times.
Solved! Go to Solution.
on 20-02-2024 01:54 PM
Hi Leanne,
Receive texts works. When someone calls me the caller receives a message that the number doesn't exists.
I have now done a factory reset of my phone and it seems to be working!
on 20-02-2024 12:30 PM
Can you receive texts?
What happens when someone calls you?
Speak soon 🙂
on 20-02-2024 12:32 PM
Have you tried restarting it?
Hi Leanne,
on 20-02-2024 01:55 PM
Hi Mystiqueen,
I did a factory reset of my phone and that seemed to have done the trick
on 20-02-2024 02:11 PM
Thanks for the update, @RichardRennes 🙂
on 21-02-2024 06:41 PM
I have the same issue since Dec 2023.
Can you tell how was your issue solved?
on 21-02-2024 06:49 PM
Welcome to the EE Community, @ELENA2177 🙂
Have you restarted your phone since your number transfer completed?
on 21-02-2024 06:54 PM
I have restarted several times and doesn't seem to work. My friends when trying to call me receive an automated voice call that my numer doesn't exist.
on 21-02-2024 07:00 PM
Hi @ELENA2177,
Can you make outbound calls?
If you can, do recipients see your ported number or a temporary EE number?
