Calls on tablet
Lwaite91
Hello
My daughter Levono tablet has just been delivered. She can receive and send texts but no calls. I haven’t included minutes in her contact so is this why? But the line goes dead when I ring her? Tried several times to clean the sim etc but it can’t be a network problem if she can text.
Thank you
@Lwaite91  Just because a product can support such a feature (. Does it have a phone app ? ) . it doesn’t mean the network has to support that service for that device.
Yes it has the phone app which is why I was confused why I couldn’t call it from it from a separate device.
Leanne_T
Hi @Lwaite91
Thanks for coming here.
The account may have a call bar as this is a tablet plan.
If you would like to discuss this please call us on 150 if you have an EE phone or 07953 966 150 from any other phone.
EssexBoyEE
Not All WiFi + Cellular Tablets can make a Cellular Phone Call, even if they have a  Phone App or you have Installed such App, could also be as suggested that you have a Data Sim Plan, but these are not normly Call Restricted on the EE Network. Try making Call to EE on 150 (should be a Free Call) and see if that works, if not remove the Sim from the Tablet put it in a Mobile and try Calling 150 to test that way.
