23-12-2025 09:05 AM - last edited on 23-12-2025 01:10 PM by Alex_H
Is sending texts abroad free?
IE. From USA to UK or within USA to a UK mobile number.
23-12-2025 10:13 AM - edited 23-12-2025 10:15 AM
@mackenzie86 That’s called roaming and you purchase an add on to use your allowance while there if your tariff doesn’t has this included with it. ( you dont have to purchase any add ons it’ll probably just cost more if you don’t )
While the text will come from tariff allowance it just depends on what tariff you have or even you need to purchase any add ons,
23-12-2025 11:38 AM
Thanks Chris,
I have bought a USA data sim, for using messenger etc so I do not want to purchase any roaming add ons.
Regards
Alasdair.
23-12-2025 12:57 PM
If you want to totally avoid any roaming charges, be sure to not send any text messages or make/receive any calls whilst abroad.
The only thing free to do whilst using your phone on foreign networks, is to receive text messages.
23-12-2025 01:14 PM
No, if it is not included in your roaming allowances, sending a text costs 93p on contract or 60p on PAYG each.
