I’m paying £25 a week but can’t make voice calls
Wrighty60
I have the same problem. I’m paying £25 a week but can’t make voice calls. I can’t call 150 and the bot service just goes round and round in circles. What can I do?
As you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise  you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
It's usually better to start your own thread explaining your issues, than tacking onto someone else's.
It sounds like you're currently roaming somewhere in Zone 1 and are having problems making calls. Can you send & receive text messages? Can you use mobile data? Have you been able to make or receive calls on this trip previously?
Try manually cycling through each local network in turn - do they all have the same issues?
Thanks. I’ve done all the things you suggested I check and still no luck. Rebooting, moving Network and still no way to make calls. I can make WhatsApp calls and FaceTime calls so can I use the number on your reply to contact CS?
WhatsApp, Facetime, Messenger and numerous othere are internet-apps that carry usage as data, in the same way as Sky Sports, BBC News and any other app.
You can only contact other users of that app, and EE-CS don't use them. If there was a way of using them, you'd have been advised of them previously.
