LivG98
I’ve had the same issues in the US.
1) have previously been able to make calls on other holidays
2) manually tried other networks and none work
3) can’t make in country calls - no calls at all (unless on wifi or 4G (WhatsApp/facetime))
@LivG98 : Did you receive a Welcome text upon arrival?
Was this in the EU or in any non-EU countries? Roaming - the ability to use foreign networks - can be enabled on an EU-only, or fully global, basis.
Use of internet-apps proves a working internet connection, but is otherwise irrelevant. To be clear, are you able to use internet-based functions over a mobile network? Or are you purely using WiFi?
This will help prove your roaming ability, if you're using mobile data whilst roaming.
