roaming
Andyt58
I'm in Australia, have bought 7 day passes to use my phone as in the UK, can't send texts or make any calls, driving me nuts trying everything possible in settings to fix this, no joy, can't even contact EE to discuss problem, anyone out there got any suggestions or suffered the same, thanks
Andyt58
Hi, activated roaming whilst in UK, received text immediately upon arriving in Australia, bought 7 day pass which should enable my phone to operate as if I was in UK, can access data, no txt or calls, can't call EE to have a moan up, have tried every conceivable option within cellular settings to no avail, have contacted EE through the complaints section within my account, not holding my breath on response, time difference not helping either, much appreciate your prompt response to my original question, cheers, will advise if I get any satisfaction, will check on my account to see status on roaming, many thanks for your help
Can you be more specific about which settings you've tried?
The relevant one would be to do a manual network search, cycling through each local network. See if the symptoms are the same.
Roaming is self-evidently active because you've received a text message thus have a local network connection. Are you using an Apple or Android phone?
Andyt58
Hi, using an iphone, my dilemma has now been resolved, you are correct, I turned off automatic network selection and was able to find the best local signal, managed to contact EE using a borrowed phone, spoke to the tech people and was informed that they had a glitch on their system, so hopefully that will reflect in my next bill, and get a refund on the time I've lost, many thanks to all who responded, all is good for now, cheers
Christopher_G
Thanks for coming back to let us know, @Andyt58
I'm glad you managed to get your phone working. Enjoy the rest of your trip. 🙂
