phone wont work abroad
brez01
Hi, i’m currently in poland but my phone will not work unless i’m connected to wifi. please can you help? i’ve done the usual checks and everything is turned on that shlild be
Your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. I've no idea what you mean by "the usual checks" but the only relevant one is to check whether you've enabled roaming on your SIM.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
What are the "usual checks"? The most usual check I see here is that Data Roaming, erroneously called just Roaming, is set ON in their phone's settings. That's not even a sufficient check! You should've checked that Roaming is enabled on your EE account. This is usually done on contract by texting ROAMING to 150 before leaving the UK. Did you?
