23-09-2025 05:57 PM
My phone was working up until today on Italian networks but now has stopped. V annoying as need to use maps etc whilst out. I’ve tried manually connecting to all the networks and turning phone on and off etc. Anyone got any advice?
23-09-2025 06:12 PM
Did each of the local networks give similar symptoms?
What does happen when you try using mobile data? Can you make & receive calls?
23-09-2025 07:14 PM
23-09-2025 07:36 PM
Removing your SIM will prevent you from having any network access - but risks the loss or damage from physical removal. If you want to try a disconnect/reconnect, then flight mode will achieve the same ends.
Everything you've described, points at a local issue with the Italian networks.
25-09-2025 06:47 AM
