iPad data not working abroad
ashleycardwell9
Hello all. I have a new Apple iPad that's on contract with EE. Works fine in the UK but doesn't abroad.
Add-on.ee.co.uk - says I am roaming abroad and have plenty of data but any other website outside of EE doesn't work. I can log in to my EE account on the iPad but everything else just won't load. Nothing else in my browser works, no Gmail, no app store. I'm connected via 5g on the same network as my phone. Any suggestions?
ashleycardwell9
Thanks for your replies. Currently in France. It was a contract upgrade. I have roaming on my package.
Phoned EE and spoke to tech support. The spend cap had glitched and was locking out data.
@ashleycardwell9 : Is the iPad on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Where in the world are you? If you are outside the EU, then your UK allowances are not applicable and you'll need am add-on of some kind.
ashleycardwell9
