abroad
danielle20024
hi. I am in Turkey and when i try to ring to England my phone just disconnects and I cannot ring anybody. Please let me know what to do. I need to contact home.
Thank you
Danielle
1 ACCEPTED SOLUTION
Ali_A
Hi @danielle20024
Welcome to the EE Community.
Do you have signal on your phone, are you able to call any Turkish numbers?
Here are some things to check:
Try switching your mobile off and back on.
Try connecting to an alternative mobile network in Turkey
When calling UK numbers, be sure to use the international format. e.g. +4479....
Have you adjusted your Spend Cap to allow chargeable calls? Visit How do I set up and manage Spend Cap for my mobile
You can check the cost of calls at ROAMING IN TURKEY AND NORTHERN CYPRUS
Have a look at What Should I Do Before I Travel? | Roaming Help for some handy tips.
Let us know how you get on
Ali
Ali_A
Hi @danielle20024
Ali
