Zone 3 roaming Pakistan
spiyaa
Hi
I used to have roaming in Pakistan 120 min for 20£ to make and receive calls from UK as add on. now couldn't find that add on any more , Just found that one day pass.
Is that month add on still available ?
1 ACCEPTED SOLUTION
No, it all changed on about 4th Dec. It is now £7.50 / day for unlimited calls & 500 MB data. You cannot use your usual UK allowances outside the EU but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/pakistan.
6 REPLIES 6
Thanks @XRaySpeX   for your reply. for £7.50 / day , does it include local calls and calls to UK and receive ?
The daily charge covers calls all calls both inbound & outbound. As per the link posted in the previous reply...
Yes, it includes all normal non-premium calls & texts
Does the 24 hours start from the moment you purchase it
or does it have a set time limit like 1am to 1am next day
or does it start from the moment you purchase it and 24 hours from the moment you purchased it
@Mohammed1248_ : It starts from the moment you purchase it and lasts exactly 24 hours from then.
