USA roaming pass
Lyonsjohn45
I added the Roaming Pass £25 before leaving the UK. I am now in the USA and I am not getting any mobile data to work, yes I switched phone on and off and yes mobile data is on.
@Lyonsjohn45 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
