Travelling to Turkey
Tracey196601
Hi I'm travelling to Turkey and I will not need roaming as I always use WiFi in hotel , do I need to set up roaming and increase my 0 spend cap anyway , I'm new to EE .many thanks
Katie_J
Hi @Tracey196601.
If you do not plan on using roaming or purchasing a pass you would not need to increase your spend cap OR set up roaming before you leave to use WiFi.
Increasing your Spend Cap will ensure no charges can be made outside of your current allowance so may offer extra peace of mind,
Hope this helps and you have a fantastic time.
Katie
Tracey196601
Hi , I'm travelling to Turkey, I only use WiFi at hotel , so don't need roaming , do I still need to set it up before we fly and do I have to increase the zero spend cap , I am new to EE, thank you
Katie_J
Hi @Tracey196601.
Katie
Northerner
Hi @Tracey196601
Make sure you use a VPN on unfamiliar WiFi.
