27-01-2026 08:17 PM
Hi
I'm currently in Australia for a couple of weeks, I have my cellular data switched off and my roaming, but I have recieved a couple of Texts. Would these have been recieved using WiFi?
I don't want to get any charges, and trying to use app is useless as it wants to use a 2 part authentication which is a Text.
Also, why is there no way to get in touchh with EE without texting or calling?
It's very frustrating trying to communicate with EE when you're in another country, couldn't find an email address.
27-01-2026 08:34 PM
@S1monJohn : No, texts never come over WiFi. They come over the normal mobile network & they are free to receive worldwide.
EE provide no email contact.
27-01-2026 08:34 PM
27-01-2026 08:42 PM
@S1monJohn Cellular data is just data and calls/texts don’t use data so you’re still connected to the network provider you’ve just got no data. Ie you can not send/receive emails or any app that needs a data connection to work. If you don’t want to incur charges for calls/texts use airplane mode on your device and just use WiFi.
27-01-2026 09:03 PM
@S1monJohn wrote:I'm currently in Australia for a couple of weeks, I have my cellular data switched off and my roaming, but I have recieved a couple of Texts. Would these have been recieved using WiFi?
Roaming means using your phone on foreign networks. If your phone connects to any Australian networks, which is necessary to send or receive text messages, or make/receive any calls, you are roaming.
Receiving text messages is free globally. I think you've probably disabled data roaming, which is a common device setting but has no impact on voice-call-roaming or text-message-roaming.
Incidentally, EE doesn't allow data roaming unless you have an add-on covering its cost - which usually means having an add-on enabling access to your UK allowances whilst roaming. The end result, is that the phone setting to disable it is immaterial.
As an aside, EE offer flat-rate roaming in Australia for £25/week now - that means access to your UK call, text & data allowances including your incoming calls being zero-rated. In the likely overall cost of your trip, it may be worth considering the relative value.
