Sim card abroad
IjeomaElliott1
Hello
I live abroad but have an ee sim as UK is my home country. But I am unable to receive calls, receive OTP no. Text. Please can you check why this is the case from your end
IjeomaElliott1
I have a dual sim card phone. One is EE and the other is MTN South africa. I need to be able to us my EE sim as I receive calls and OTP text from the UK. How can this be fixed? How can I turn on my EE phone sim whilst I am here in South Africa?
Hello
I live abroad but have an ee sim as UK is my home country. But I am unable to receive calls, receive OTP no. Text. Please can you check why this is the case from your end.
@IjeomaElliott1 : Can you make calls & texts?
