Set up and paid for roaming through app, won’t connect SOS only.
ChrisE56
I have same issue. Arrives in Texas, set up and paid for roaming through app, won’t connect SOS only. Called technical services via skype, no fix just wait and see after 24 hours and call again. I’ve been to uk numerous times and never had issue before but this time both my wife and I have same issue.
any advice out there?
@ChrisE56 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
ChrisE56
Well after two Skype calls to technical support it’s fixed. They eventually took off roaming and reapplied it. Then I took out the SIM card, reinstalled and it all worked! I don’t think technical support really knew what the problem was but they persevered and it’s fixed. Thanks to Chris at technical  support !👍
Katie_J
Thanks so much for letting us know @ChrisE56.
Take care,
Katie
