Service restricted
KristapsZ
I am travelling in America and it seems that I can't call or send text messages to either of the customer support numbers. Nor I can send text to 150 with anything.
Any idea what is going on?
@KristapsZ
If you need to talk to us while you’re away just call +44 7953 966 250.
This call is free to make whilst roaming in the EU, to make this call outside of the EU, you’ll be charged the standard roaming rate for where you are.
150 will not work because the roaming network doesn’t know where to send that message too.   Ie there’s no area code for the UK which is 44
Just to check did you enable roaming on your account before you left the UK ?  This is done by texting ROAMING to 150.
michael23578925
For outgoing text messages whilst roaming, the above is not accurate. The phone is sending all messages via EE's UK SMSc by virtue of +44 7958 879879 being programmed into the SMS settings.
