Re: Roaming refresh
Daniel19782
Just arrived in Romania but I cannot activate my roaming
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app such as Skype over WiFi..
