Rouming
Hyqi376
SIM card does not work in Ukraine, SMS messages and calls do not come
@Hyqi376 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
@Hyqi376  are you on contract or PAYG  if on contract did you enable roaming by texting and roaming to 150 before you left the UK ?  if on PAYG did you use that sim in the UK first ?  Does the device show it’s connected to a network?
