on 25-02-2023 04:45 PM
hello, I bought a SIM card online, I am now in Poland, will the card work if I start using it in the EU (I am not going to England)?
Solved! Go to Solution.
on 25-02-2023 08:11 PM
@Bohdan0504 : Did you use that PAYG SIM for making calls or texts in UK before you left to go abroad? EE PAYG SIMs need 1st activating on EE's home UK network before they can be used abroad. If it wasn't you can't now use it until you return to UK.
