Roaming
Precious5
I have apis to roam in France on holiday for 5 days and my roaming isn’t working Ineed help. What do I do
@Precious5 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
