Roaming overseas
maipenrai
Roaming overseas is supposed to be easy but removing the spend cap is a nightmare if you have more than one device on the account. The app tells you to log in online and when you do that you’re told to go to the app. Just a doom loop of frustration.  The app is very poor.
@maipenrai   So you text SPEND CAP to 150 and change it via text for that device you are using.
