Roaming not working
Frustrated_EE
I have an iPhone 16 and work
in Canada I have roaming but cannot make
 calls to normal phones. I have tried for almost 30 minutes to speak to a real person at EE and cannot get past the merry go round of press this and press that and we have sent you a text message that inevitably leads to press this and press that . Data roaming is turned on and has been toggled and yes it has been paid for, any suggestions before I totally bin EE
@Frustrated_EE    if you can ring customer services then you can make normal calls as this is what ringing customer services is.    Go to settings/apps/phone scroll to the bottom and is dial assist enabled ?
@Frustrated_EE : Did you receive a Welcome text upon arrival?
To add to the posts already...
This is just a phone setting that enables mobile data whilst already roaming. If roaming isn't active, it's futile. And voice-roaming doesn't use mobile data.
As per the previous reply... what exactly do you mean by "I have roaming"? Does your phone show a connection to a local network? What happens when you try making a call?
I have tried ringing, and texting this morning as I put in the message and I always end up in a loop of pressing Thai and that number and text messages no real person
