15-10-2024
08:00 PM
- last edited on
15-10-2024
09:19 PM
MikeT
😢but what if you didn’t do this before leaving the UK? I can’t seem to contact customer services by any means. Thanks in advance for any help.
15-10-2024 08:45 PM
Your post has been moved to a new thread, you've not clarified whether you've travelled abroad with a PAYG phone or pay-monthly.
