on 17-02-2025 08:26 PM
I have landed in Morocco but forgot to initiate roaming to Morocco before I left. I don’t seem to be able to send text or even go onto 4G/5G briefly to buy a data bundle for the day?
Solved! Go to Solution.
on 17-02-2025 08:30 PM
