Roaming in USA stopped working
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-10-2024 02:49 PM - last edited on 10-10-2024 10:51 AM by Peter_W
Hello
I am on holiday in the USA. I paid for roaming before I left the UK and when I arrived I received the "Welcome to the USA" text and my phone connected.
I had another flight so went into airplane mode and when I turned that off, I have not reconnected.
I have tried restarting, turning off and on again, turning airplane mode off and on again, manually finding a network etc but with no success.
Any help please? Thanks.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-10-2024 01:04 PM
Hi Peter,
I have just checked and I don't have a spending cap in place.
When I try to connect manually, the message I get is "selected service is not available".
Thank you,
Rich
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-10-2024 01:08 PM
Cheers for checking that @Rich19651.
Is it the same message if you're trying Verizon, AT&T and T-Mobile?
I was in the US this time last year and it would sometimes switch between these networks depending on the best connection available.
Peter
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-10-2024 11:16 AM
Hi Peter,
Yes it is the same for all networks unfortunately. I tried again connecting manually to each one and then turned the phone off, then on again and tried autocorrect but to no avail.
It is working fine when I can get WiFi but not at all without it.
Rich
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-10-2024 11:54 AM
OK, thanks @Rich19651
Are you able to access the live chat option in the 'help' section of your EE App? If you're able to get in touch that way, they'll be able to check everything is as it should be from our side.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-10-2024 12:08 PM
Hi Chris,
Thanks for the suggestion.
I have tried the live chat but it just goes through the same things I have done and then asks me to call which I can't fo unfortunately.
Rich
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-10-2024 12:53 PM
OK, thanks for trying, @Rich19651
The only way this can be looked into further is if you speak with our Mobile/Technical support team. I know it's a bit more difficult when you're abroad, but I know of others using the contact numbers through a VoIP service, such as Skype.
- « Previous
- 1
- 2
- Next »
