24-08-2024 10:05 AM
I can’t use my phone or increase my spend cap to use in spain
24-08-2024 11:38 AM
24-08-2024 12:50 PM
Hi @Jeanlinda,
Thanks for visiting the EE Community 🙂
I am sorry you are having an issue using your phone in Spain.
As @bristolian mentioned this could be caused by not having the roaming enabled, in which case it would require reaching out to one of our guides on the Skype number they have supplied.
If you do have a spend cap in place, this could be causing the issue as well as you mentioned because using the phone in Spain will have a £2.47 daily charge, if you go to Manage> Settings> Spend Cap, is it showing a cap active and are you able to then disable it from here ?
Alex
25-08-2024 01:09 AM
@Jeanlinda : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
